Rover 200 & 400 Owners Club • Wheel spacers? Plus extended studs? possible?
Posted: Thu Mar 06, 2008 6:39 pm
by roverconverted
Heys guys,
I want to fit some wheel spacers to my rover 216... Is it possible. I will have to change the length of the studs right??? If so how>??
Cheers
Posted: Thu Mar 06, 2008 6:56 pm
Why do you want to fit spacers? They aren't necessary if you fit the correct offset wheels.
Posted: Thu Mar 06, 2008 7:14 pm
by roverconverted
Cheers for your reply,
no there is no rubbing issues just wondering if there is a set out there that has spacers and longer studs, just the wheels i have now the bolts dont come all the way through. So it would solve both probs?
Any ideas?
Posted: Thu Mar 06, 2008 11:07 pm
by Warnzee
Ive got a set of OMP 15mm hubcentric spacers. Brought them to use on my Chevette, but the centre bore is wrong :blushing
They're really high quality kit, not a cheap bodge. RRP is around £95!! Got no real use for them tbh, sell em for £45? Never been used, only trial fitted.
Not sure about extended studs, but try Demon Tweeks, or maybe some kit car places? Usually a good source of non-standard stuff.
Re: Wheel spacers? Plus extended studs? possible?
Posted: Sat Jun 11, 2011 8:07 am
by jhnharvy773
roverconverted wrote:Heys guys,
I want to fit some wheel adapters & spacers to my rover 216... Is it possible. I will have to change the length of the studs right??? If so how>??
Cheers
Looking into getting some wheel spacers, just need some advice.
How big of a spacer can I run without needing longer studs? Also, where is the best source for longer studs if I need so?
Posted: Sat Jun 11, 2011 2:54 pm
by Fatdave
5 or 6mm i would think is the most i would dare run. if you want bigger i would'nt bother extending the studs. go for hubcentric spacers, they dont tend to be cheap though. if you get some of these you can choose what stud pattern you want too. ford, jap whatever.
if your handy with the tape measure you could probably get your local engineering shop to make you some.
Posted: Thu Jul 21, 2011 9:07 pm
by stubby44
These are the ones fitted to our 216 GTi race car made by Super Forma. We run 20mm but they will make them in any size. Superb quality!
http://forum.jdmgarageuk.com/showthread ... -ebay-shop
Posted: Thu Jul 21, 2011 11:55 pm
by Fatdave
what race series do you run in and will you be at cadwell at any point?
