Post HG woes
Posted: Tue Apr 22, 2025 10:53 pm
Hi All
Well as per a previous post my HG has gone, not just the minor leak from the head/block join at the front of the engine as it was but the full coolant in the oil type. Though not visa versa and it never overheated, so I decided to do it myself.
I’ve gone elastomer HG with full cambelt and water pump kit from DMGRS.
Not an easy job and a bit fiddly but seemingly all went ok as the car starts, runs and drives, does not seem to overheat and coolant is not flooding out everywhere.
But, but, but.
The car ran absolutely fine before the work smooth and quiet.
But now it runs a little lumpily, it still drives ok and revs (though I’ve not used many revs). At tickover with the bonnet up you see the engine rocking in a slightly uneven way as it just doesn’t run quite correctly.
Def not like this before.
So what have a screwed up and what do I need to do to smooth it all out again.
Cheers Bean
But, but, but.
Cheers Bean
