Page 1 of 2
some pics of my engine re-build so far
Posted: Thu Jul 26, 2012 6:55 pm
by r1ckyg89
finally solving my oil burning problems out, got the cab down at craigs. Heres a few pics of it so far, judging by the pics my engine was in a realy bad way
http://s1127.photobucket.com/albums/l623/ickysky1/k10/
Re: some pics of my engine re-build so far
Posted: Thu Jul 26, 2012 7:20 pm
only need some bearing and we're back on the road.
Posted: Thu Jul 26, 2012 9:31 pm
You'll be needing a good looking cam cover to go on your rebuilt engine, surely.....
http://www.rover200.org.uk/forums/viewt ... =21&t=6170
Posted: Sat Aug 04, 2012 5:52 pm
by r1ckyg89
where can i get a nice new 1 from?
Posted: Sat Aug 04, 2012 5:59 pm
Doesn't need a new one just a refurb.
Posted: Sun Aug 05, 2012 9:25 am
My 'spare' is available - it was £20 on ebay. So for the same it can be yours....
A can of wrinkle paint later and it'll top off your engine bay nicely
Posted: Tue Aug 07, 2012 10:45 pm
by martinhodge
hondas burn oil. always have done always will do . on the vtecs its common for them toburn a litre a month or 2 ifyou hammer it alot *laughs* . even says that in the honda build manuals from honda *laughs*
i can point you in the direction of a bran new bottom end for 100 pound if u like
Posted: Wed Aug 08, 2012 6:28 am
Only need to the shells adding and timing and start nipping some bolts up and job is done...
and oil
Posted: Wed Sep 12, 2012 8:18 pm
I can confirm this rebuild was completed and runs so smooth its unreal.
Total cost of job including parts £415, happy to do another one if needed as long as your not in any hurry.
Posted: Fri Sep 14, 2012 6:17 pm
by Mr Teddy Bear
If your engine is burning oil [ vaporising from around the piston/cylinder wall] as opposed to leaking valve oil seals, try using a fully synthetic quality 10-40. Much higher resistance to oxidisation.
My previous 216 GSI started using a bit of oil from 100k miles onwards ran that on Castrol though. Put that down to leaky exhaust valve seals, as she still went well. I had her from 3 years old and put 100,000 on the clock. As some one else so neatly phrased it " you don't realise what a good car a Rover 200 is until you've got rid"
A change from Castrol to Shell Helix cured my Merc! Semi Synthetic isn't actually synthetic at all, in case anybody still doesn't know. Sorry if I'm teaching you to suck eggs by the way.
TB
