IMG_0917 by max_burton, on Flickr
IMG_0929 by max_burton, on FlickrThis was my prize, a solid, low miles (64k), running, MOT'd early 416, with a fresh MOT and two new tyres, for £375. I got it off bramz, who I think is on here and Autos***e, he's had a couple of R8s - this one, and iirc a dark blue 216GSi manual with blue leather.
It's pretty much spot on mechanically, it just needs oil/filter, ATF, and a few sundries as a matter of course - precisely what it needs, I'm checking tomorrow, then doing. Only issue is a slight misfire/running rich, and the thermostat seems to be stuck open as the gauge usually reads C, sometimes climbing to 1/3, so either a dicky 'stat or the temperature sender is duff.
Everything electrical works too.
The reason I went home via Merthyr Tydfil (aside from the fact it's way more fun to , is because a bloke on the R8 enthiusasts' FB page (and seems to be on AROnline, not sure about here) was selling some White Diamond doors:
IMG_0920 by max_burton, on Flickrthe rear passenger door is badly stoved in, with broken paint. I knew I needed the one door, and as I was there, decided to get both rear doors - the driver's rear door has a minor dent in it, and a patch of rust at the top, which I'll happily swap for a bit of lacquer peel. I had the two doors and a passenger mirror off him, asked what he wanted and he said £30
From there it was just a leisurely drive home through Wales.
I've already got a replacement front indicator lens for the n/s as repros are a tenner on eBay, stick that on tomorrow too. Got two correct GSi trims coming too, as the car came with two GSi trims, and four facelift SLi trims - not arsed about those though.
Oh and it needs a valet/can of Neutradol as it's all musty inside!
Watch this space...
