Track R8 214 Sprint
Re: Track R8 214 Sprint
These are mine.
JOHNDQ
Post by JOHNDQ »
Yes I think I came across those ones at some point can't remember looked at so many. The other reason when for these ones is Drew from Roverdose (name may be wrong) said he supply's and uses them with no problem... So far :laughing2 I'm hoping to be on track in March to try them :wink3
JOHNDQ
Post by JOHNDQ »
Got the other camber arms today and glad to say they will work perfect :tt2 got plenty of room for adjustment from standard to around -3 degrees (could go more with coilovers i think as trailing arm hits the lower shock body) So thats one job sorted on to the next hundreds :tumbleweed
ImageIMG_20180125_190402~2 by John Quincey, on Flickr
ImageIMG_20180125_182622~2 by John Quincey, on Flickr
ImageIMG_20180125_182807~2 by John Quincey, on Flickr
ImageIMG_20180125_182739 by John Quincey, on Flickr
ImageIMG_20180125_182837~2 by John Quincey, on Flickr
ImageIMG_20180125_182713~2 by John Quincey, on Flickr
Vulgalour
Post by Vulgalour »
Those white multispoke alloys look really nice against the factory colour.
Current Fleet:
1980 Austin Princess 2 1700 HL
1994 Rover 414 SLi
JOHNDQ
Post by JOHNDQ »
Don't think be brave enough for white wheels, you should see the dust that comes off the pads and if you leave it you can't get it of :mouthshut I've got GTI wheels to fit once I've got front discs made up (has 330x28mm at mo from ZR) just need to see what biggest disc and run hoping for 295x28mm. Not sure on wheel colour yet. Engine bay will be white, engine and gearbox be the orange that's on wheels, bottom half of car and trim be same top half and the red strip in trim be same as wheels.... What ever that will be :laughing2
JOHNDQ
Post by JOHNDQ »
First of the bushes came today, in this case trailing arms :D Going for Powerflex Black Series which is meant to be there motorsport compound. Cant believe how hard they are they are like solid plastic :o going to be a bumpy ride :mouthshut
Image2018-02-08_07-28-26 by John Quincey, on Flickr
you want to pay full retail knock yourself out.
could have got you up to 20% of superflex ones.
JOHNDQ
Post by JOHNDQ »
Superflex bit to soft had those before plus i get these at a really good price from a friend who's a dealer at 35% discount of RRP.... every little helps and all that :wink3
JOHNDQ
Post by JOHNDQ »
Little update, trying my best to get ready for POL in some form anyway. Got the engine bay just about stripped ready to get it painted hopefully can get done next weekend.....
ImageIMG_20180311_162853 by John Quincey, on Flickr
ImageIMG_20180311_162913 by John Quincey, on Flickr
Just need to finish sanding the panel for the ZR subframe rack to smooth it off, bearing in mind made it from starch came out ok.....
ImageIMG_20180311_164210 by John Quincey, on Flickr
And finally got engine and gearbox on stands ready to paint before fitment.....
Image2018-03-11_06-01-25 by John Quincey, on Flickr
Vulgalour
Post by Vulgalour »
Hoping the next stage goes quite smoothly, it looks like you've got everything lined up and ready to go.
Current Fleet:
1994 Rover 414 SLi
