Track R8 214 Sprint
redandwhitE
Re: Track R8 214 Sprint
Understand.....shame that our better halves never do!
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
2004 45 imp Petrol
1998 Audi Cabriolet
True all tho to be fair she isn't to bad about it this is the 3rd car now so I'm under orders it has to be the last
redandwhitE
....and there's always motorbikes or steam engines or vans or buses or.......
2004 45 imp Petrol
1998 Audi Cabriolet
2004 45 imp Petrol
1998 Audi Cabriolet
I like your thinking but after Devo divorce can't imagine be much left over for that
Well at last the engine is finally in was starting to think this day would never come....
IMG_20180401_165107~2 by John Quincey, on Flickr
IMG_20180401_192711~2 by John Quincey, on Flickr
IMG_20180401_192730~2 by John Quincey, on Flickr
IMG_20180401_192743~2 by John Quincey, on Flickr
IMG_20180401_192743~2 by John Quincey, on Flickr214 Sprint track car
Well unfortunately weather didnt play ball this weekend but got a fair bit done on Saturday so fingers crossed should be at POL. Anyway while the weather was bad today i got the loom made that will link the engine to the engine bay fuse box and into the car. Just need to test fit it to make sure everything is the right length and i havent missed anything before covering it with flame and fluid resistant heat shrink....
2018-04-08_09-57-23 by John Quincey, on Flickr
2018-04-08_09-57-23 by John Quincey, on Flickr214 Sprint track car
Just a quick one to keep thread going. Unfortunately due to work and kids party's at weekends still running behind but not far off now just the final bits of wiring, coolant pluming and exhaust to sort and should be there i think.
Another few of wiring, hoping to have it finished this week still waiting on the Deutsch crimpers to come so can get the multi plugs on....
IMG_20180420_001624~2 by John Quincey, on Flickr
IMG_20180420_194500~2 by John Quincey, on Flickr
Few of the car finally got the bumper top coated and the panels back on....
IMG_20180422_202929~2 by John Quincey, on Flickr
IMG_20180422_202945~2 by John Quincey, on Flickr
IMG_20180422_203537~3 by John Quincey, on Flickr
IMG_20180422_203549~2 by John Quincey, on Flickr
Ive also booked the car in my local car show "the haynes 100" (idea is to have a car from each year covering 100 years) in June to cover 1993
IMG_20180420_194500~2 by John Quincey, on FlickrFew of the car finally got the bumper top coated and the panels back on....
IMG_20180422_203549~2 by John Quincey, on FlickrIve also booked the car in my local car show "the haynes 100" (idea is to have a car from each year covering 100 years) in June to cover 1993
Well started what i thought was going to be a easy job today. Thought i would get the Coupe bonnet flatted and grill holes sorted ready to get painted next week so flatted the top coat down....
2018-05-06_09-39-38 by John Quincey, on Flickr
But once i took off the top coats found a few touch up and poor repairs.....
2018-05-06_09-39-55 by John Quincey, on Flickr
So had to take those spots back to bear metal and add a skim of filler....
2018-05-06_09-41-22 by John Quincey, on Flickr
2018-05-06_09-41-46 by John Quincey, on Flickr
Then flatted again followed by a coat of high build primer...
2018-05-06_09-42-06 by John Quincey, on Flickr
Then the joys of a wet flat of first 1200 followed by another wet flat of 2000 to get it nice and smooth.....
2018-05-06_09-42-29 by John Quincey, on Flickr
So after best part of the day its really for the body shop but bearing in mind its only getting used on track and will most likely be stoned chipped first time probably been a waste of time.
2018-05-06_09-39-38 by John Quincey, on FlickrBut once i took off the top coats found a few touch up and poor repairs.....
2018-05-06_09-39-55 by John Quincey, on FlickrSo had to take those spots back to bear metal and add a skim of filler....
2018-05-06_09-41-46 by John Quincey, on FlickrThen flatted again followed by a coat of high build primer...
2018-05-06_09-42-06 by John Quincey, on FlickrThen the joys of a wet flat of first 1200 followed by another wet flat of 2000 to get it nice and smooth.....
2018-05-06_09-42-29 by John Quincey, on FlickrSo after best part of the day its really for the body shop but bearing in mind its only getting used on track and will most likely be stoned chipped first time probably been a waste of time.
Bit more done today just getting wiring finished hoping to get the ignition on tomorrow at last....
First off adding the Solder sleeve's onto the shielded cables to allow any noise to travel to earth for the Lambda and crank sensor signals. I dont run a cam sensor on mine engine so only 2 needed....
IMG_20180510_205342 by John Quincey, on Flickr
Few of the plugs and terminals using gold plated terminals for all sensor signals and standard for power and grounds....
IMG_20180509_211736 by John Quincey, on Flickr
Adding in the splices for common power and grounds and covered with Motorsport Raychem spec ES2 end caps.....
IMG_20180509_211716 by John Quincey, on Flickr
For the join between the engine bay and inside ive used Motorsport spec Deutsch DT Series plugs so should the engine need to come out i just need to disconnect the plugs and all wiring from the engine and engine bay fuse box etc will come all together nice and easy with the engine with all sensor signals on 1 plug, powers and ground on the other 24 pins in total. The plugs are mated male to female, female to mate so i cant mis-match them and blow the ecu.....
IMG_20180510_183717~2 by John Quincey, on Flickr
And finally i stripped, cleaned, rebuilt and sprayed the Alternator as everything else has been done....
IMG_20180509_211924 by John Quincey, on Flickr
IMG_20180510_205342 by John Quincey, on FlickrFew of the plugs and terminals using gold plated terminals for all sensor signals and standard for power and grounds....
IMG_20180509_211736 by John Quincey, on FlickrAdding in the splices for common power and grounds and covered with Motorsport Raychem spec ES2 end caps.....
IMG_20180509_211716 by John Quincey, on FlickrFor the join between the engine bay and inside ive used Motorsport spec Deutsch DT Series plugs so should the engine need to come out i just need to disconnect the plugs and all wiring from the engine and engine bay fuse box etc will come all together nice and easy with the engine with all sensor signals on 1 plug, powers and ground on the other 24 pins in total. The plugs are mated male to female, female to mate so i cant mis-match them and blow the ecu.....
IMG_20180510_183717~2 by John Quincey, on FlickrAnd finally i stripped, cleaned, rebuilt and sprayed the Alternator as everything else has been done....
IMG_20180509_211924 by John Quincey, on Flickr214 Sprint track car
Aaronrover214cab1993
Looking great mate nice chat the other night too the time flew *laughs*JOHNDQ wrote: ↑Thu May 10, 2018 8:22 pm Bit more done today just getting wiring finished hoping to get the ignition on tomorrow at last....
