Minus the head gasket and timing belt being replaced a few years ago, i've got no idea of the service history of the car. The condition suggests it's been looked after pretty well, but we'll see what demons I find
A non-exhaustive list of what needs doing so far:
- Air filter, fuel filter, spark plugs and an oil and filter change
- Replacing a sheared bolt from the head cover
- Swap the odd wheel trim for a matching one
- Repair the detached head lining
- Replace the rubber head cover seals around the spark plugs
- Work out what's triggering the alarm
- Rust!
First bit i've done is get the fuel filter and spark plugs swapped. No idea how old this filter is...
New one in! I'm no mechanic so i'm reasonably pleased with how this went.
Next job will be the air filter!
