200 cabrio electrical gremlins
Posted: Thu Aug 04, 2022 5:06 pm
Hi folks,
I recently joined the club having bought a 94 200 cabrio (1.6). I had a 214sei back when they were nearly new and loved it. I’m thoroughly enjoying the cabrio so far especially with the weather.
I’ve had a few minor electrical issues since buying the car which was unused for a fairly long period.
First thing I noticed is that neither the interior light or boot light work. The clock clearly doesn’t have 12v to keep the time when the ignition is off (this is a recent change). Also the radio has no permanent 12v and the boot open dash warning light comes on dimly on occasions (again a very recent thing).
I’m assuming these are all going to likely be earth problems but I wonder if anyone can point me in the right direction to find the various points to clean. I’ve cleaned the one on the slam panel and that actually seemed to make things worse as that coincided with the clock losing its memory. It did thought cure the issue with only 7v going to the radio from the ignition switch.
I also noticed that the clock illumination goes darker when then drivers door is open.
Gary
Gary
