Page 1 of 2
681 Radio/Cassette
Posted: Mon Aug 18, 2025 9:50 am
by BlairHobson
I have the above in my Concerto. Up until now I've never used it but having recently got a cassette I'd like to try it. I pushed the on/off button and a light came on behind the large volume button but the display didn't light up and the cassette didn't play however much i pressed the mode button. Do I have to key in the code before the display lights up or is it knackered?
Re: 681 Radio/Cassette
Posted: Mon Aug 18, 2025 3:10 pm
by Montegoman
It should come up with a C if you need to input the code. Does the radio work?
Posted: Mon Aug 18, 2025 6:32 pm
by BlairHobson
No sound at all, just the back light behind the volume button.
Posted: Tue Aug 19, 2025 7:39 am
by Montegoman
If it is not showing anything on the display, I would guess that the display has failed. It should show a C if it is asking for the code to be inputted.
Posted: Tue Aug 19, 2025 12:24 pm
by StubbornPatriot
I suppose it could be possible that it is asking for the code but because the display has failed you can't see the -C-. If you know the code, it is probably worth trying to enter it and see if that is the problem.
Posted: Wed Aug 20, 2025 11:37 am
by BlairHobson
Yes, I thought that as well, so tried it, but it didn't work! Knackered is I think the phrase!
Posted: Wed Aug 20, 2025 12:37 pm
by BlairHobson
Right, took the radio, an R652, out of the 216 that's off the road and stuck it in the Honda. Bingo! The lights come on and I get the - C - on the display. Trouble is i have no code!
Posted: Wed Aug 20, 2025 1:19 pm
by BlairHobson
Sorted!!
The R652 worked and we can now listen to The Seekers on our way to Pershore (whether they like them or not!!).
Posted: Thu Aug 21, 2025 8:37 am
by 216CAB
I'm intrigued as you said you didn't have the radio code; how did you then manage to get it to work?
The Seekers get a big thumbs up from me!
Posted: Thu Aug 21, 2025 1:23 pm
by Topcat Tomcat
[quote
[/quote]
I won't object to them. I'm just about old enough to remember seeing their last concert on the tv.
If you're unlucky, might see you again......provided I don't drop off!
