Flywheel Visible at rear of Engine 214SI 1994?
Posted: Wed Nov 11, 2026 4:03 pm
by Mark A Wright
I have a query regarding my 1994 Rover 214SI; its been running a bit sluggish at low speed so Ive changed the SparkPlugs, HT Leads and the Distributor Cap & Rotor Arm, the Distributor Cap connection were very pitted and the Rotor Arm didn't look too good either, so this may have a bearing on the performance issue?
Also I went to replace the Crankshaft Position Sensor hidden under the engine at the rear (what a pain this is to access!!) - and this is where I have the query; in peering down the rear of the engine under the inlet manifold, I can see the Flywheel through an opening in the engine casing, there appears to be bolt holes adjacent this, so is there suppose to be a cover plate covering this opening on the engine?
I know from speaking a a previous owner that the owner before him (now deceased) supposably had the clutch renewed? So if there is a cover plate (?) its feasible the garage didn't replace it??
Any advise is gratefully received, and if there is a cover plate required, where on earth would I get one!!!?
Hopefully you can see the issue in the two photo?
regards
Mark
Re: Flywheel Visible at rear of Engine 214SI 1994?
Posted: Wed Nov 11, 2026 4:19 pm
by itcaptainslow
There should be a thin metal cover that bolts there. I’ll see if I can find the part number for you later.
Posted: Wed Nov 11, 2026 4:33 pm
by Mark A Wright
itcaptainslow wrote: ↑Wed Nov 11, 2026 4:19 pm
Cheers; Im on the Stand at the NEC show on Friday with you so maybe we can discuss further then
Posted: Wed Nov 11, 2026 6:19 pm
by 961tat
Mark A Wright wrote: ↑Wed Nov 11, 2026 4:03 pm
regards
On rover coupe stand Saturday I bring one with me
Chris
Posted: Wed Nov 11, 2026 7:48 pm
by Mark A Wright
961tat wrote: ↑Wed Nov 11, 2026 6:19 pm
regards
Chris
Cheers Chris, I'm not on the Rover 200/400 stand on Saturday but I'm planning to attend the show so will catch you then.
cheers
Mark
Posted: Thu Nov 12, 2026 7:37 am
This is how we all help each other
