Power steering hoses
djt2912
Post by djt2912 »
Hello all,
I have experienced major PAS leaks in the last few days with my 220GSi. Investigation suggests that my high pressure power steering hose is leaking badly but I cannot find any stockist for this part. :headbanging I have also looked up under Rover 820 as I believe the same PAS system was used for this car as well. Does anyone have any ideas where to look for these things?
Thanks!
Re: Power steering hoses
Some of the power stearing pipes are in stock with Rimmers, not cheap mind!
I've got a used spare setup in the garage at the moment if you know which part you need.
djt2912
Post by djt2912 »
That sounds useful! I will take a closer look on the weekend and clean more of the leakage away so I can confirm my original diagnosis. Does your set up include pump or is just hoses?
Just hoses. One has previously been repaired (professionally) I believe. It was all attached to a rack/subframe I bought some time back. I only used the subframe so everything else is currently cluttering up my garage floor.
