R8 drivers door
MatthewL
R8 drivers door
Post by MatthewL »
Hi there. Been doing bodywork on my Rover driver side which has gone quite well. I have a long journey to do over the weekend and tonight after testing the car was ok - I got back, went to shut the driver door…. And it won’t shut. Will get as far as first catch but won’t shut fully. Can’t see anything getting in the way (in the dusk). I rolled the door catch with my finger which seems ok for first and second catch. The door hasn’t sagged. All suggestions welcomed. Going to look more in the light in the morning
MatthewL
Re: R8 drivers door
Post by MatthewL »
Definitely nothing blocking it so it’s either check strap which looks fine - nothing should stop that going in, or the catch needs adjustment- but the door sits flat when shut. Anyone had the same issue?
In all fairness the passenger door easily “flops” shut. The driver I’ve had resistance the last inch. So I’m loathed to move the catch. I think that would address the symptom not the cause.
g259fsg
Re: R8 drivers door
Post by g259fsg »
I've had that problem years ago with the metal door strap limiting the opening. I found some bolts had come loose and the mechanism was a bit bent. Might have to take off the door trim panel to see what's going on inside, which is where most of it is.
MatthewL
Re: R8 drivers door
Post by MatthewL »
Ive been holding off but I think that the next step …
C6Dave
Re: R8 drivers door
Post by C6Dave »
g259fsg wrote: Tue Sep 03, 2024 7:54 am I've had that problem years ago with the metal door strap limiting the opening. I found some bolts had come loose and the mechanism was a bit bent. Might have to take off the door trim panel to see what's going on inside, which is where most of it is.
Taking the door panel off is straightforward, but I had problems getting the passenger front back on when fixing a lock issue. It took half a dozen attempts to get it down properly on the inner skin lip :roll:
1991 Rover 200 1.6 GSi - Lynx Bronze
1980 Triumph Dolomite 1500 SE - Black
MatthewL
Re: R8 drivers door
Post by MatthewL »
I’ve checked everything - it’s not the check strap or the latch position on the body … it looks like it’s a broken door latch -
Passenger and below the driver door for comparison - looks like a plastic bit is sheared off.
So….. HELP! Does anyone live near Leeds and have a spare I could buy please?
Matthew
redandwhitE
Re: R8 drivers door
Post by redandwhitE »
Yes.
I've a 400 with both latches. Get in touch tomorrow and we'll sort something.
Cheers
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
MatthewL
Re: R8 drivers door
Post by MatthewL »
Thanks very much! Have sent you a private message. I put on there that it’s urgent but in reality I’ll have to try to borrow another car so I’m just keen to get hold of one! Cheers
