power steering
Day971
power steering
Post by Day971 »
power steering on my 216 coupe is very heavy compared to other coupes. tyres are correct pressure and no fluid leaks. any ideas guys
Re: power steering
Has the pump lost its ability to generate pressure?
Is there a blockage anywhere in the system?
Has something gone mechanically stiff?
I would suggest putting the front end of the car up on axle stands and turning it lock-to-lock with the engine off first - does it move easily and smoothly?
Then do it with the engine on - any difference?
Then put the wheels on the ground - ideally on pairs of oiled steel plates to reduce tyre friction, or do it on as smooth a surface as you can find, like a painted floor. Does the pump sound strained?
Is this a Honda or a K 1.6? I may have a spare pump if it's the latter...
Day971
Re: power steering
Post by Day971 »
Thanks for the reply, will try your suggestions over the weekend. Mine has the honda engine so hope its not the pump!
