clock on dash not lighting up but still works?
marke
Post by marke »
anyone have any idea how to fix the light on the clock on the dash on a 96 418, the clock works but is hard to see it ??
Red Icon
Post by Red Icon »
There's a bulb in the back of the clock, you have to prise [carefully] out the clock mounting trimstrip from the facia, withdraw the trim and disconnect the wiring connector from the rear of the clock, tie a piece of string around the connector incase it falls back into the facia, the clock is now clear and you should see the bulb. change it and replace.
marke
Post by marke »
top man! i`ll give that ago tomorrow mate does the wood efect strip just clip off then? thanks
Yep. Work a blunt flat object behind the trim from the passenger side toward the centre and it just unclips forward.
nick
Re: clock on dash not lighting up but still works?
Post by nick »
hi there in the old shape rover it is a replacment bulb may be the same.
nick
