Clock illumination
jalopyjoe
Clock illumination
Post by jalopyjoe »
Anyone know if the clock in my 216GSI should be backlit? If it should be how do I get to the bulb to change it?
Joe Richards
1993 216Gsi Auto
216GSi
Post by 216GSi »
Yup it should be back lit by a sexy orange glow :tt2
You'll need to carefully prise the wood strip out to change the bulb. If you start on the sweeping bend on the left hand side by the passenger door it will pop out as it's only held by retaining clips.
HTH
1995 Rover 220 Coupe turbo (62k)
Dorset_Clive
Post by Dorset_Clive »
With the emphasis on CAREFULLY :angel
If you use a large flat blade screw driver, that will spread the load on the trim.
The bulb is a horrible little panel illumination type that is almost, but not quite the same as the instrument panel illumination size. Doh :S
Clive
"Paint your life in bright colours"
Sir Robin Knox-Johnson
jalopyjoe
Post by jalopyjoe »
Thanks guys, I'll have a go at it over the weekend.
Joe Richards
1993 216Gsi Auto
