One of mine split a while ago, so i replaced it, but i'm thinking that if ones gone, then the rest are probably in the same sort of state.
So i thought why not go for some Samco silicon jobbies, as they'll last forever (ish) and look better, and as they're heat resistant, the hose that sits right on top of the exhaust manifold should hold up a bit better.
BUT Samco only seem to list for the Coupe/GSi Turbo.
Are the coolant pipes the same between the Turbo and non-Turbo?
Thanks in advance, Rich.
