Well my 75 Clutch gave up last saturday so the Cabriolet was then nominated to
be the daily driver, it lasted 2 days before I spotted this.
Upon closer inspection under the bonnet I found a rather empty bottle.
After consulting 'The Almighty Dist' I ventured under the car and found this.
So a tinker day was setup on Thursday with mtecstevo to replace the water
pump but since this requires playing with the cam-belt we decided that it
would be wise to replace it as I have no idea when it was replaced last or if
it has at all.
Before stripping fully we did a compression test just in case the head
gasket had been compromised, the results were as follows.
1- 15
2- 14.5
3- 13.5
4- 13.5
Not the worst results, a bit uneven but within tolerance.
As we started popping bits off the engine we found the dizzy cap points were
quite worn out so that ended up going on the list with the belt.
The rotor arm was also past it and a couple of the spark plugs were also
worn out so I ordered a full ignition system, Plugs, Leads, Dizzy & Rotor.
The water pump looks like it has been leaking for a while.
Stevo then summed up the damage MAD MAX 2 style *laughs*.
LINK: https://www.youtube.com/watch?v=ZYr5TDfHxjc
Since I had a headgasket and bolt set already he suggested checking out
the current one since we were doing the cambelt and waterpump so off
with the head it was.
Now we were at this stage I decided to take the plunge and blow the dust
off these that I have had lying around for a few years now.
They are MG TF 135 Cams, they were upgraded cams with a higher lift
and fitted to the non-VVC 1.8 but can't see why they won't improve the
1.6 in the Cabby, shame it can't be remapped or chipped as it is MEMS
1.9, I do have an SuperChips ICON Race Box but there is no support
offered for it but I may look into it again as I also have a VVC inlet
manifold lying around so that will be fitted too, it is off a 1.8 but the
ports on the 1.6 are the same, this is becoming more than a waterpump
repair, its an engine overhaul and upgrade.
For anyone interested the lift on the 1.6 standard cams is: 38.8mm
The lift on the MG TF 135 cams is: 39.5
Combined with the inlet manifold it should get a good gain.
Anyway, on with the removal of the cylinder head, the cam carrier got a
light cleanup, the oil was decent and the engine looked well maintained.
The headgasket looked like the original, if so its laster 90,000 miles but
it is on its way out, probably a result of the waterpump, looks like its on
about 75% integrity.
The head and block surfaces looked ok, some staining, light corrosion and
pitting but a rub down with some 1200 grit wet and dry on a wood block
with a spray of WD40 brought them up a treat and we now have a nice
fresh surface for the new MLS gasket to sit on.
This is as far as we could go until the shopping list arrives, on order we
have the following, if anyone would like the links I will get them as it was
a bargain, £107 for the lot.
Cambelt Kit - GATES
Waterpump - Comline
Sparkplugs - NGK Platinum
HT Leads - HighVolt
Rotor Arm - Intermotor
Dizzy Cap - Intermotor
Keep an eye out for Part 2, the rebuild, weather permitting we will be
cracking on with this on Monday or Tuesday.
