The other being a serious one, I left the car for 3 weeks and battery drained flat, I managed to open the driver's door with the key and removed battery for charging.
After charging battery, as soon as I connected the leads the Alarm comes on and won't reset from the key fob, (Rover 214 SLI, 4 door 1.6 Honda engine)
Alarm stops after about 30 seconds thereabouts
No amount of fiddling with the key fob buttons does anything, I checked various sites for as much information and all failed to restore the alarm deactivation.
The only thing I didn't try was the EKA as I do not have a code
I also noticed that when I use my ignition key to open or lock the driver's door (Passenger door has no key locking ) the central locking does no longer function on any of the 4 doors, there was a fault on the driver's door where the central Locking did not function but on 3 other doors it functioned Ok, I used the Fob to disable alarm and then unlock the driver's door with the ignition key.
The previous Owner told me that if I unlock all 4 door locking buttons, and reconnect the battery, and press on the "LOCK" button on my Fob 5 times in a quick succession it should sort it out, but it hasn't. I tried all possible tricks mentioned on various sites, but none to any avail.
1. Could it be that because Central Locking doesn't work, hence the problem why it won't disable?
(I haven't checked the CL fuse in case it is blown, will do this tomorrow)
2. I suspected that it may be the door micro switch (central locking switch) which is operated by turning the ignition key in the driver's door,
I checked it had two wires connected to it, (A black with yellow marker and a black which later on connects to another connector with two different colours i.e. black/red and black/yellow) and I checked with my Multimeter and it buzzes when the pip on the microswitch is pushed in, so making a connection and goes open circuit when the pip is out. (Door key upright vertically the pip is out so contacts are open, when key turned contacts close)
I also got Rover 216 & 416 Haynes Manual, the circuit diagram shows a two way switch i.e. single pole change over switch with 3 wires, whereas on my 214 Rover it only has two wires, hence why I think turning the ignition switch on the door to locking or unlocking position would make absolutely no difference as the cam on the door switch simply kicks the pip on the micro switch with just two wires to make or break and would not indicate which direction the switch is being turned, so putting in the EKA code may not work on this car as there is no way the switch would know if it is being turned to left (unlocking) or to right (Locking)
Sorry for being a long post but better to clarify and provide as much information available.
Please kindly suggest what my options are? can it be rescued, can I rip out immobiliser from the car if assuming it is not integral part of the ECU as in many other cars which uses a transponder, I do not think there is any transponder in the Fob.
I have also tried all the tricks in the Owners Manual , like re-synchronising etc, but absolutely nothing, the red light in the dashboard flashes on off as if armed, and each time I open the door the horn starts sounding and engine is immobilised., If i leave the door open, the red light goes steady after alarm stops 30 seconds later.
Thanks in advance.
