Help Please - Cam Lock kit to borrow
donnyvfr
Post by donnyvfr »
I am looking to borrow a cam locking kit to lock everything up when i do the belt shortly!!!!
Has anyone local (ish) to Doncaster got one i could borrow please?
of course there would be a bottle in it for you!!!!
pajan1
Post by pajan1 »
Paul New Member
If you go to halfords they will be able to supply you with a cam lock tool for about £6.00
hope this helps
Paul
Ps Its normally a draper tool.
donnyvfr
halfords
Post by donnyvfr »
none of the halfords local or fairly loal to me have them, looks like i shall find something to fit when i do it tonight
If you can't find anything then just mark up the pulleys and head with tippex so you can put it back exactly as you removed it.
donnyvfr
Post by donnyvfr »
well its looking good..... new water pump This was the job to do originally as i had a water leak, first i found it to be the daft pipe with the O rings, but then i think it must have been like this for a while as once i did that it started pressurising properly and thats when the water pump started leaking!!!!
So while its apart daft not to put a belt on whilst its stripped down as i don't know when it last had one!!!
Anyway its back together and seems to be running ok so i am keeping fingers crossed now that i don't get any more leaks!!!!
Hers's to the next 165000 miles!!!!
