Ghall2004 "RoboCoop" 220 Coupe Turbo Spec/Progress
Post pictures of your car here. We want pics!
ghall2004
Re: Ghall2004 "RoboCoop" 220 Coupe Turbo Spec/Progress
Post by ghall2004 »
rear end now "amy winehouse" spec
need to re center reg plate as was a guess at pol when changing plinths to oe turbo decal
ghall2004
Post by ghall2004 »
Time to get thy geek on
"show points" spec
Hose clip has been installed here (* for the h8ers)
"full on Oe" look rear end, this is to give me a much a chance of retaining a oe look to the car with the sutble mods to the styling ext in terms of wheels etc
ghall2004
Post by ghall2004 »
As another member has pointed out another coupe to me as being "inspiration"
time for rubbish to get real
hadnt used the da for over a year, forgot all my process i had picked up from detailing forums etc and tbh really cant be bothered anymore
it was summer up here today in edinburgh and felt the need to see how much i could restore the paintwork like on the coupe
( paint job is needed and i am now saving for this)
o/s roof after wash
General condition of bonnet
time to see whats embedded in the paint
clay bar after pass on o/s roof section, very clean to be honest, very little fallout picked up
panel/working area masked up
swirling in abundance
Using the AG two stage paint correction system today for quickness, stage one is the "cutting" stage
after a few passes with stage 1, a lot better, but not amazing, but i can see a section of failed clear coat coming through so cant do much more to this section in all honesty
Stage 2 refine
And a quick coat of HD wax
Need to check wax applicator pad as application of wax appears to have induced swirling again :(
50/50 on the bonnet, again, better but, lots of chips and defects, and swirling still present
Some more new stickers and brake fluid advice tag
Front rub strips now black(spare set)
ghall2004
Post by ghall2004 »
Summer again today in norway
n/s panel above windscreen ( tbh needs repainted )
a couple of quick passes later and this is as much as i want to spend here, lifting paint were rust is bubbling so will just leave be
50/50 shot showing, whilst still rubbish its an improvement
roof section i was working on yesterday, as you can see, RDS and swirling still present
Again vast improvement, but the entire body has scratches that haven been painted over at various stages
Moved onto the only area which was totally unacceptable, even until pending respray, the bonnet
prepping underway
extent of paint defects
Moved back to the roof for another go
Bonnet after initial pass
as you will agree, horrendous, and just wast improving, just far too many RDS and clear coat failings
50/50 pre wax vs untreated side
check the crazy scratches
n/s after refine and 1st coat wax
now onto the other side, pre work sit rep
tbh didnt spend too much time on the other side, post passes of restore and refine
again notice crazy marks and scratches
final wax coat applied
Moved onto tidiy up a few areas at the back
after
yes i know excess compound is on the letters
Moved the onto some more "modz" as my haters like to call them
catch can/tank install
installed and first section of stainless braided hose cut to length and installed ( remember this pipe jase? *laughs*)
second section installed and leads down to samco s bend feed
extent of orange peel and swirling to the n/s
only did a quick pass with the restore compound to tidy marks up, so still terrible but wasnt doing anymore
continued with dress up of bay
reason for mate socket caps is the old bolts had snapped here so had to drill out and tap/thread
h8 away
ghall2004
Post by ghall2004 »
Coming soon
Alloy cam coves from Beef (OVERSPORT)
as also seen on PeteT16's ZST16T
ghall2004
Post by ghall2004 »
Also coming soon to a coupe in norway
Gaz :mrcool:
And prior to my major pas network fail, i was cleaning bits
before ( already semi clean)
after
ghall2004
Post by ghall2004 »
Updates
Some progress has been made on the cooling side of things
Replacement uprated radiator is finished and awaiting collection
Commissioned and supplied by Cableguy,as part of the radiator services he offers( NO BREACH HERE, RECOMMENDING SERVICES/PRODUCTS ONLY) it is a Rover sport tomcat racer radiator essentially, with slight modifications
Above images show the rad in production, and the following one shows it finished ( more detailed images will be posted on a separate update come installation time)
Improvements over the original design are as follows:
* End tanks modified for better flow to all four cores, compared to the RS one which is limited, on the first and fourth
Also some new images of the recently refurbished Oz Supperleggera's i bought from RY220 after the demise of N150
Some before shots
Left them with Cableguy after my recent parts run down to the midlands coupled with 4 brand new yokohamma parada spec 2 rubber, to have them stripped back and overhauled , powder coated gloss black
Ok no my car they are against, but this was done at my request. Hope they work ok on the car.
I am over the moon, the works carried out look to be of the very highest standard. So thanks to Cableguy for facilitating that.
ghall2004
Post by ghall2004 »
29.4.14 v2
Some more "D.I.Y" shizz
Cleaned up the "first" group buy Skunks to be fitted, installed around start of Nov 2012
You can see they are honest and where i bodged them to fit. Aint no garage queens here. hate away. 16k miles and numerous "laps" as my hecklers will tell you i never completed a lap on track in N261, what evs
Scotch winter and roads for you now, these were pristine oct 2012, and were removed from N261, Goodridge braided lines
= PUMPED
Completed the Engine bay "dress up " kit
Started work prepping parts and components for the overhaul front to back of the suspension system top to bottom
Spare front anti roll bar
Tie rods/brake reaction bar with poly
Condition of rear discs and calipers intend to "upgrade" with
Front roll bar with first coats of hammerite red smooth to smarten up
Rear anti roll bar gets the same treatment
Condition of rear 260mm discs
Resolved the pas system leak thanks to CABLEGUY AND BLACKSHADDOW, offending item here
Rear Discs/Caliper rescue work
Few passes with the random orbital disc sander
Before
choice of weapon
New front control arms
Removed poly inner bushes from old arms i had in stock
Burning of the new inner bush out
Fitted
Painted to help protect as long as i can( not long i know but better than bare)
Anti roll bars more paint applied
Turned attention to Front of car
Before reference shot
Abs rings are failed, cracked open and causing abs to kick in, cv gaitors also at the end of 20 years service, swapped for working items from n261, and issues now resolved
"just leave it alone" they say, sure with drop links like this, jokes on you suckka's
o/s before reference shot
Trw TRE, possible original tbh, these are to replaced when i fit the Golds and the Cableguy top mounts and get the Geometry set up
dark images, but condition of ball join nuts were so poor i had no choice but to cut away until i could break free with force
Failed cv boot at some stage
TCA inner bush
n/s drive shaft replaced with a much healthier and fully functional abs ring
New front Tca in place
front anti roll bar in place and new ARB poly "d" bushes installed
poor pictures please excuse
Out with the good stuff
o/s after wax
n/s after
drop links also poly bushed
Very pleased with my weekends "DIY" mechanic work. Car is slowly approaching the way N261 drove when i first got it.
Do not underestimate the effect of new ball joints. I am now going to be doing these on a yearly basis at mot time
Hate away
*apologies for disjointed nature of the photos, just the order i took them/uploaded, and the spelling mistakes and poor grammar
ghall2004
Post by ghall2004 »
Update 4.5.14
Forge Dv fitted
Alloy T Series Cam Covers By Oversport/Beef
Test fits were disappointing with the polished effect, out comes the enamel workshop red paint( same paint as used on the inlet plenum)
Work in progress
Heavy duty quality clear coat applied
Ready to offer up
before shot for reference
after test fit#1
test fit#2
Toying whether to fit or not
Onto fitment supplies at the ready
Thread locker
Silcone sealant ( as covers have no in built rubber gasket etc)
Plate type gasket for rear cover to help with splash from oil as no in built cover or fire trap
Installed
Stainless meshing added to catch can and also inserted into area at exit at one way valve end
Coil overs in transit to me, so rear end overhaul due for next weekend, then wheels and brake upgrade package
ghall2004
Post by ghall2004 »
Ups delivered these puppies for the w@nky rust bucket
