oil leak on 2.0 rover engine.
mr shifter
Post by mr shifter »
is it possible for the 2.0 rover engine to leak a load of oil but not coolant from the head gasket? :)
andburg
Post by andburg »
yes its fairly normal, the T series is known to weap on from the from right of the head, but normally its the cam cover seal rather than the headgasket.
if it is from the headgasket I'd recommend replacing it with a Klinger gasket
Wanted 216 twincam GTI
mr shifter
its pouring out not weeping!! :blink
C2K
Post by C2K »
Yes it's common to do that. Klinger head gasket is what you need.
2001 Peugeot 306 HDi
1994 220 GSi Turbo - FOG
tompinney
Post by tompinney »
Could also be camshaft seals if the oil is running down the side of the engine rather than the front. Mine was pouring oil out of them when they failed. Couple of quid for replacements from rover and they're relatively easy to replace... bit mucky mind!
Tom
Above all, it's a Rover!
-1993 220 Coupé (2008 MG Saloon Day 'Best Modified Rover')
-1993 420GSi Sport Turbo (The 'Rumm Chuff' :))
rover220
Post by rover220 »
welcome to t-series ownership
mr shifter
sounds like head gasket, oil is pouring onto the exhaust manifold!! where can i buy the modified headgasket,
thanks everybody!! :D
rover220
Post by rover220 »
mr shifter wrote:sounds like head gasket, oil is pouring onto the exhaust manifold!! where can i buy the modified headgasket,
wont be headgasket if its on the manifold
andburg
Post by andburg »
yep cam cover oil seals
