I know I've been away for a while but I'm hopefully getting 220gti back off Craig and one of the things that still needs doing the mid rail coolant pipe needs replacing.
Problem is I don't have the part number for it.
Don't suppose anyone could help out please.
Thanks in advance.
Help with a part number for a part.
Re: Help with a part number for a part.
Have you looked on Rimmer's site should be there, or rather the part number should be. I suspect it's nla? You could always use those numbers from RIMMER to search Ebay and the web, though?
If all else fails, is it a simple enough part to get someone to fabricate a stainless replica perhaps?
I rang Rimmers and they only have it on microfiche and isn't on their site for me to look at.Mr Teddy Bear wrote:Have you looked on Rimmer's site should be there, or rather the part number should be. I suspect it's nla? You could always use those numbers from RIMMER to search Ebay and the web, though?
I gave them the Reg from the Gti but I need the vin number from Craig to get the actual part number from them.
I'm also half expecting it to be NLA but at least as you say I can scour the net to try and locate one.
