geabox oil
crepello
Re: geabox oil
Post by crepello »
Mr Teddy Bear wrote: Mon Apr 30, 2018 5:58 pm Remember it's fitted with plastic caged bearings!
The tips of the selector forks on the early R65 are also plastic! The forks are stamped from steel sheet.
On the later uprated gearboxes, the forks are machined from bronze castings, deleting the separate fork tips. An ex-BL transmission guy who sold me an R65 explained that lazy drivers who used the gearstick as a hand rest were thought to keep the tips in constant pressure and cause premature wear.
Re: geabox oil
About 18 months ago in 2016, I looked into this after some suspected gear-selection problems on our 214 R65 gearbox. The guy at a local gearbox repair firm, recommended using Automatic Transmission Fluid (ATF) in the box rather than 75W-80 GL4. I had tried EP80W-90 but without any real improvement in the performance, and he thought this oil would be too thick in cold weather and make gear changing difficult. I drained it out and put in Dexron III ATF. With the gear-change mechanism sorted and the ATF in the box, the transformation is remarkable. It's very slick, like a new car. Previously I have been using Total BV 75W-80 which was the oil originally specified by Rover for this box in 1990. Other Club Members have suggested using MTF-94 gear oil
I wonder if other owners have tried ATF in the R65 box and whether there might be any concerns that it isn't providing as much protection for the gears and final drive as GL4. I suppose if it's good enough for the gears in an automatic box, it should be OK in the manual. The guy from the gearbox firm said that quite a lot of manual boxes now use ATF and it should be no problem, particularly with a bit of the EP still left in there. Another similar firm in Rutherglen, “Top Gear”, also recommend ATF in manual boxes, see http://www.topgear.uk.net/faqs.html
Here's a small table of the specs for the viscosity of various oils at 40 degC and 100 degC. Total BV 75W-80 was the original specified oil for this box. It looks to be quite a thin oil relatively, somewhere in between MTF-94 and Dex III. Another possible contender is Castrol Syntrans, another thin MTF.
Gear Oil, Viscosity 40 degC, Viscosity 100 degC
Castrol Syntrans FE 75W, 32.2, 6.3
Castrol Dex III ATF, 35, 7.2
Castrol Syntrans B 75W, 37, 7.3
Total BV 75W-80, 49, 8
Texaco MTF-94, 53, 10.5
Fuchs 75W-85, 81.5, 12.1
Castrol EP 80W-90, 133, 14
I used the Dex III ATF for about three months with good results, and then drained it and replaced it with the original Total BV 75W-80 I’d taken out earlier. The feel of the gear change isn’t markedly different. Perhaps a bit more notchy, and slightly harder going into first and second gear. I think in a little while I’ll revert to the Dex III as it gives a smoother slicker feel to the gear change. Changing the oil in the Rover 214 gearbox is a bit of a pain as the top filler hole is rather inaccessible. I’ve made up a right-angles tool out of some 15mm plumbing bits, with the pipe narrowed down to go into the gearbox filler hole. It’s also easier to screw the filler bolt back in from under the car.
18 months and several thousand miles later using Dex III, the gearbox is performing well without noise or gear selection problems, apart from occasionally being reluctant to go into fifth gear. We've just returned from a 1100+ mile road trip without issues on the gearbox.
1965 Humber Sceptre Mk.1
1966 Hillman Minx Series VI
pkronic
Re: geabox oil
Post by pkronic »
g259fsg wrote: Thu May 03, 2018 9:58 pm About 18 months ago in 2016, I looked into this after some suspected gear-selection problems on our 214 R65 gearbox. The guy at a local gearbox repair firm, recommended using Automatic Transmission Fluid (ATF) in the box rather than 75W-80 GL4. I had tried EP80W-90 but without any real improvement in the performance, and he thought this oil would be too thick in cold weather and make gear changing difficult. I drained it out and put in Dexron III ATF. With the gear-change mechanism sorted and the ATF in the box, the transformation is remarkable. It's very slick, like a new car. Previously I have been using Total BV 75W-80 which was the oil originally specified by Rover for this box in 1990. Other Club Members have suggested using MTF-94 gear oil
so i could use dex iii? its only temporary till i can get new seals and oil but we have dex iii here my dad uses for his range rover transmission. dont want to put it in and too rude to say the gearbox but i need the car and havnt got cash for acouple days
Re: geabox oil
Dex III certainly seems fine on my 214 and no problems so far.
pkronic
Re: geabox oil
Post by pkronic »
g259fsg wrote: Mon May 07, 2018 3:22 pm Dex III certainly seems fine on my 214 and no problems so far.
how long have you been using it total? miles or time
pkronic
Re: geabox oil
Post by pkronic »
ive just put my faith in u *laughs* it only need to go till weekend then seals and new oil should be here
Re: geabox oil
18 months and probably around 3000 miles, including a recent 1100 mile round trip to Longbridge. So far no concerns about the performance of the gearbox, and no nasty noises.
pkronic
Re: geabox oil
Post by pkronic »
g259fsg wrote: Mon May 07, 2018 7:26 pm 18 months and probably around 3000 miles, including a recent 1100 mile round trip to Longbridge. So far no concerns about the performance of the gearbox, and no nasty noises.
well i shall give it a good test with the amount of miles i drive haha
redandwhitE
Re: geabox oil
Post by redandwhitE »
ignore this post.....for my reference only
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
Re: geabox oil
redandwhitE wrote: Thu Jul 19, 2018 11:51 am ignore this post.....for my reference only
You can bookmark or subscribe to a thread via button just under this text box :)
