Track R8 214 Sprint
Want to share photos and details of your projects? Then post them here.
Re: Track R8 214 Sprint
damn thats a hella press :scared
JOHNDQ
Post by JOHNDQ »
Yeah she a beast have to go easy and watch gauges one of the juniors managed to split a brake drum by trying to press the bearing out the wrong way :headbanging
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi Dunlop challenge race car
JOHNDQ
Post by JOHNDQ »
A little cosmetic update for change since ive got no new parts to fit :unsure finally got round to doing a job thats been bugging me since got the car. It have various rust spots on the drivers door where i would guess its been opened against something and knocking the paint off so thought i would address it now before they become holes....
Took it down to metal to grid out the rust....
Image2019-03-31_08-14-02 by John Quincey, on Flickr
Then i put on some rust treatment, a good coating of anti rust primer and a coat of high build primer followed by a flatting off to smooth the surface....
Image2019-03-31_08-14-50 by John Quincey, on Flickr
Than the top coat, unfortunately i just used a tin of the Halfords paint so the colour match is a bit off (to light) but im not to worried as its not a show car just glad not to be looking a rust every time get into it :tt2 .....
Image2019-03-31_08-15-06 by John Quincey, on Flickr
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Little update on the 200, not done anything with it for a while now unforgivably but finally got the L/R brake master cylinder on and all the brake pipes made etc. Ive used the Rover reservoir as the L/R unit is to close to the throttle bodies....
ImageIMG_20190530_185803 by John Quincey, on Flickr
ImageIMG_20190530_210526~3 by John Quincey, on Flickr
ImageIMG_20190530_210540~3 by John Quincey, on Flickr
ImageIMG_20190531_200730~2 by John Quincey, on Flickr
216 GTi track car
216 GTi DOHC
Vinny1979
Post by Vinny1979 »
WhAt are those adapters
I’ve just put a Land Rover 300 tdi master cylinder on
Used the lr reservoir too
It’s close on the t series to inlet
1993 Rover 220 GSi Turbo , 2005 MG ZS 180 mk2
JOHNDQ
Post by JOHNDQ »
It's a M10x1mm through bulkhead adaptor
216 GTi track car
216 GTi DOHC
Vinny1979
Post by Vinny1979 »
Thank you
Great thread. I like the gearbox pics.
JOHNDQ
Post by JOHNDQ »
Touch wood the gearbox Seema to be working ok so far :laughing2
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Another little update since its been June/July since the car has been started or even moved :S I decided to let the little Rover have a break over end of summer and put the Evo on the road for a while....
ImageIMG_20190915_091420~2 by John Quincey, on Flickr
ImageIMG_20190915_083815~2 by John Quincey, on Flickr
Any way back to the R8, made a few changes to been it into line with the regs for the race series i want to run in. The major one is the fact i have to run the factory size wheel from the range so shes finally back on 15" wheels :D ....
ImageIMG_20191027_151425_2~2 by John Quincey, on Flickr
ImageIMG_20191027_151357_2~2 by John Quincey, on Flickr
That being said brings a few good points, looks better and i can set the car lower but the on the negative side means i cant run the big brake kit so im down to ZR160 282mm discs and calipers :scared Im also going to have to use the 216 GTI wheels (which are heavier than the 17's) because the Turbo wheels rub on the 160 brake caliper carrier. Back on track next month with this set up and stiffer coil springs for a bit of test time to see what happens :tt2
216 GTi track car
216 GTi DOHC
JOHNDQ wrote: Sun Mar 24, 2019 8:34 pm Yeah she a beast have to go easy and watch gauges one of the juniors managed to split a brake drum by trying to press the bearing out the wrong way :headbanging
I bet it came out though...*laughs*
