That's fair enough. I wasn't trying to be an ass, just curious, as it appeared from memory that there wouldn't be the room to get the shell out that way without risking damage to it though bending. I've not seen the headlining out of a car, so it's probably that it is narrower than I thought and there is enough room to carefully remove it that way. The bracing is shaped more like a Saltire, rather than an X, so it is wider at the top and bottom than the sides, so it is possible that there is enough room. As you say, their own repair manual says it can be done and they should know.Johnny 216GSi wrote: ↑Sun Nov 27, 2022 6:12 pm Well, it's there in black and white in the repair manual.
The V-shape bracing obviously gives rise to a wider aperture right at the top if I'm remembering which way round the sloping V bracing goes. I assume they believe this is wide enough. I suppose they may be neglecting to mention a rubbing and bending issue, but this would be across its width not length, so it'll probably survive. Perhaps tape a cloth around the sharp bracing edges to stop them digging in and doing damage?
John made the point that during manufacture the headlining shell would have been swung in through the front windscreen aperture and front glass fitting would have been one of the last production stages. So if you fancy getting the A-pillar trim off and getting a glass tech. to cut the window out, there's another option.
When we did the one at the NEC, I did take the headrests off the front seats to allow a bit more contortion. Other people's suggestions of taking the front seats out may be an even better option and would mean you've tackled the seized seat bolts too, which you can copper grease when you refit them. But I did definitely get it out through the near side rear passenger door, and I got it back in that way too. A couple of bends in the shell in the location I previously mentioned, but it easily survived that.
As for removing the windscreen and 'A' pillar trim - oh hell no!! I would rather remove the whole set of seats before I did THAT! *laughs* At least removing the seats only requires undoing a few bolts!
