Sam 216 GTI
Introduce yourself here, a bit about you and your interests.
redandwhitE
Re: Sam 216 GTI
Post by redandwhitE »
Samwisegangie wrote: Thu Dec 14, 2023 9:52 am
redandwhitE wrote: Thu Dec 14, 2023 9:21 am Am I missing something or is the reg. about right?
Built(ish) in last third of 1990 and registered in 1991: seems perfectly straightforward.
I'd be interested in finding out why owner thinks its a 1994 car.
Was it still possible to specify the lower grey paint as late as 1994?
Register date on logbook is 1994 but car seems to have the 1991 bits
But if registered 1994, it'd be 'L' or 'M' reg wouldn't it? I'd say its a 90/91 Car ('J' reg as per your photo) and someone has had the felt tip on your logbook.
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
Samwisegangie
Re: Sam 216 GTI
Post by Samwisegangie »
redandwhitE wrote: Thu Dec 14, 2023 1:54 pm
I honestly have no idea
1994 216 GTI
1971 Plymouth duster
Samwisegangie
Re: Sam 216 GTI
JOHNDQ wrote: Thu Dec 14, 2023 12:58 pm D16 A9 is the early GTi with no cat or lambda sensor
Better or worse than cat one ?
1994 216 GTI
220 GSi turbo
Re: Sam 216 GTI
Post by 220 GSi turbo »
Samwisegangie wrote: Thu Dec 14, 2023 4:03 pm
More horsepower than cat-equipped car, lower fuel consumption and you won't go outside one morning and find that some scumbag has cut through your exhaust and stolen the cat.
And no stringent emissions test to worry about: it only needs to meet the same emissions standard as a mid-80s Ford Sierra :)
Montegoman has almost definitely given you the correct answer for the 1994 registration date (it will probably say somewhere on the V5 that the car was previously used abroad and was declared manufactured in 1991/92). Since 1983, cars previously used abroad have been given a registration plate that corresponds to the proven date of manufacture, rather than a 'new' plate.
1995 220GSi Turbo: owned for 24 years
1994 216SLi
2000 25GTi
Daily: Honda Civic Type R GT
Previously: 216 Sprint (1988-91)216 Coupe(1993-95) 214SLi(1995-96) 420GSi Turbo L955UKV(1997-2004) 214SEi M884BMR(2004-11) 420GSi Tourer (2005-6) 214 SEi M103BCW(2011-12)
Colonel Mustard
Re: Sam 216 GTI
Post by Colonel Mustard »
Based on my own experience of reimporting my 220D, the DVLA will have almost certainly based the registration on the log book from where the car was imported from. This would suggest that although the car appears to have been made in 1990, it was not registered overseas until after 1 August 1991, hence why a J plate has been issued - because that is what the car would have got if it had been registered from new in the UK at the time.
With regards to the entry on the DVLA's public facing website, the date of registration of January 1994 will be purely the date the car was first registered in the UK (ie after it was re-imported). However, I suspect the year of manufacture shown of 1994 will have been either a typo or the operative being lazy and not bothering to think about it - after all, if it was registered elsewhere in 1991 it cannot have been manufactured in 1994!
Samwisegangie
Re: Sam 216 GTI
Colonel Mustard wrote: Fri Dec 15, 2023 7:25 am Based on my own experience of reimporting my 220D, the DVLA will have almost certainly based the registration on the log book from where the car was imported from. This would suggest that although the car appears to have been made in 1990, it was not registered overseas until after 1 August 1991, hence why a J plate has been issued - because that is what the car would have got if it had been registered from new in the UK at the time.
I agree it’s a interesting story at least
1994 216 GTI
Samwisegangie
Re: Sam 216 GTI
220 GSi turbo wrote: Thu Dec 14, 2023 10:16 pm
Least I don’t have to panic at mot as much then
1994 216 GTI
JOHNDQ
Re: Sam 216 GTI
Post by JOHNDQ »
I can see this being a problem at MOT, when you enter the details on the MOT system it will give you a date of first use which in this case is going to be 1994 so the tester is going to assume the car need a cat test
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi Dunlop challenge race car
SteveB
Re: Sam 216 GTI
Post by SteveB »
JOHNDQ wrote: Wed Dec 27, 2023 5:37 pm I can see this being a problem at MOT, when you enter the details on the MOT system it will give you a date of first use which in this case is going to be 1994 so the tester is going to assume the car need a cat test
That's a good point. It's been MOT'd a few times so presumably the tester has made allowances. Does the MOT system bring up date of registration or date of manufacture?
Incidentally, my first Rover was registered about 120 numbers before this one, on 1st August 1991, so I guess this plate would've been issued around that time. I've been told it's a Birmingham registration.
