Intermotor 15750. Just Google that and try to find the best price. There should be a sachet of thermal grease in with the item if the package hasn't been opened. Smear it on the metal back of the spark amplifier / igniter before mounting with the two bolts. It fills the gaps between the metal surfaces when mounted together, significantly improving the heat transfer.
Technically, that grease is called "heatsink compound" and you can Google that too. Normally a white paste.
These days, high-performance PC builders will be more familiar with the term "thermal paste," as used between the processor and heatsink/cooler. These can be higher-performance greases as a processor without cooling will get significantly hotter than a D16 spark amplifier given the power dissipation involved.
