Philips R960 remote steering wheel controls for R8
Having problems with your club car? This is the place for asking advice and help on technical problems. Resident experts will be on hand to help you keep your car in tip top condition
Roverlike
Re: Philips R960 remote steering wheel controls for R8
Post by Roverlike »
Resistance of the switches can be measured by ohmmeter, not voltmeter.
MatthewL
Post by MatthewL »
Yes I’m using the resistance capability (messing up your 200ohm) on the voltmeter to see if I can see a reading when the buttons are engaged and therefore, I assume, making a circuit with a resistor in it. Can’t get a reading though so I’m doing something wrong.
Roverlike
Post by Roverlike »
If you are using 200 ohm range it is too small. You are expecting values of 390 ohm, 470 ohm and 820 ohm. You need to use greater scale like 2k ohm.
More recent version of steering wheel switches use 82 ohm, 120 ohm and 270 ohm values.
