Ghall2004 "RoboCoop" 220 Coupe Turbo Spec/Progress
Post pictures of your car here. We want pics!
ghall2004
Re: Ghall2004 "RoboCoop" 220 Coupe Turbo Spec/Progress
Post by ghall2004 »
Updates
Thanks to Ryan ( RY220) for the following work( please excuse the iphone 3gs tech images, Kelso is a small town who just recently got wap enabled mobile devices
:P :P )
front hubs supply
sand blast
replace front wheel bearings
primer
base colour coat
seal
ghall2004
Post by ghall2004 »
Quick update, full write up to come later once i have had the tracking/alignment done
Major front and rear end works
Gaz fitted
Top mounts fitted
Just getting the front and rear setup and all the niggling things sorted out. hoping to get TRE changed and a initial geometry reset/adjustment tomorrow
Car has been off road for a week and a half.
but its getting there, front is currently slight higher than rear, but this is where i left it for the night as car was feeling better at the front at this height. initial first drop after fitment i think it was too low and bottoming out :(
Recently re coated superleggera's and new parada spec 2's fitted
Camber was more aggressive but had to dial it out as it had thrown the already massively different TOE values, making the car un drivable. will get it setup again for around -1.5 to -2 once i have it drivable again and a baseline solid setup
need to fart about with some more things to get the best out of the front struts, then adjust bump/rebound as i go
iphone and scotch mist = rubbish images, and excuse the poor colour match on the flap
ghall2004
Post by ghall2004 »
Rear End make over
Objective here is simple. Replace and renew. Source parts as follows taken from the fallen hated N261FDH
All poly bush fitment where obvious
Rear trailing arm assembly
rear upper and lower lateral links
Skunk2 LCA
ARB D bushes and drop links
Upper shock shaft/top mount
Also to be installed
260mm zr/zs brake setup
overhaul calipers
Gaz rebuilt coilover package
Rear CABLEGUY lower brace
Upper rear brace
Stainless brake lines
things started slow, pissing down rain the whole weekend ( 17/5 + 18/5)
I feel most of the components on this car are original to an extent. Never have i encountered such rust/seized items
Off to a good start, had to spend most of the first day cutting, and grinding the inner lca bolt to chassis on both sides of the car. All bushes and roll pins solid, perished.
bolt seized in bushing/roll pin
after years of pee ing about
condition of the trailing arm bushes " leave it alone they say" what evs
lca inner bush, well whats left of it
Then this happened, just was too far gone the fitting, simply snapped when i attempted to free
Other side started to be tackled
Moving on....
Lower rear brace offered up for template/pilot holes
Waxoly the arches
Arb in mid installation
The following day i was able to start to put the puzzle back together
skunks offered up
New lines made for both sides at the back
Attention then turned to removing the top mounts from old struts
new bushes
Had to get the support of gaz, down to my rebuilt rear struts having this chammfered element to them as opposed to a traditional " step"
this meant i had to get gaz to make up some tapered washers to allow me to successfully install the rear top mounts
Now these are rebuilt "gha" bodies but uprated internals *laymen terms summary of response from gaz to the gha vs gold saga
Sneak of the goodies up front, just figuring out how to put it all together
Back to the rear end folks
struts in place and getting more complete by the minute
upper rear brace
lower shot again
Rear brakes and pretty much the rear end rear for a test run. ride height i played super safe with for initial road test
Go genuine carbon effect oz center caps or go home. simple as that
Front write up to follow
ghall2004
Post by ghall2004 »
Front end works
Objective here
all suspension bushes
new low control arms
track rod ends
coil over installation
adjustable top mounts
refurbished hub assembly and new wheel bearings
Again bushes in the their biggest part already taken care of previously
No bolts snapping or delays, front end work was more pleasurable as i had been working on front end in recent weeks
sheer stopping power of 262mm
awww nawwww, that bad already! this was just my attempt to help reduce flex on the union and hopefully not snap
20 year old tre
boom!
no pictures sorry as it was over so quickly ( thats what she said)
Had a fair bit of swapping over and re in statement to do, so i got cracking
abs brackets, aint coming off in one piece you just know it
h&r and oe FTW
the 262mm beauties again
snap!
recon untis thank to my good man Ryan paxton ( RY220)
lines also from ryan
abs sensor complete, again from ryan
rebuilding
preparation is key
top mounts first install and initial fixing process
new fixings where possible
PLEASE NOTE AFTER A SLIGHT DISASTER THE STRUTS WERE ROTATED TO SOLVE THE ADJUSTER FOULING THE WHEEL/TYRE
a lot of fine tuning needed for the ideal stance, and ride height, being a daily i need to negotiate speed bumps on route to work and also my driveway getting in and out
Off for geometry set up tomorrow and hopefully back on road for Monday.
initial camber was throwing the already mad toe off the chart and making car, combined with all other elements impossible to drive
so i brought this back a tad, and raised the front end as i need to tweak the front inset and top hat/washer combination,as i suspect aspects of work i had to do to get the shaft locked into the top mount bearing caused me to loose some tolerance on the shaft movement? hope that makes sense
adjusted bump/rebound on fronts and adjusted tyre pressures and its getting better.
this
gave this
but now is like this
thanks for looking
ghall2004
Post by ghall2004 »
Back on the road today.
Car is now drivable
Tracking ( toe and camber) were adjusted, print out to follow
not 100% happy, some values are suspect, and the place i have went to in the past after top service seemed to have changed hands
car is pulling to left and steering is off. and can just feel its not happy
I have some adjustments to the front struts over the weekend and will refine the height on all four corners. Track rod ends to be replaced next Thursday when, no only that car is drivable i can travel down to kelso to see Ry220 and his Hunter setup.
Had a semi fire this morning, right rear caliper seems to be sticky! so was a bit puffy when i pulled up at lights lolz
Also my Roversport tomcat racer by Cableguy radiator arrived. this will go on next weekend along with new water pump and revised matrix to heater valve hose ( weeping at moment)
And the best for last
h8 away fools *laughs*, say what you want. THIS FLOATS MY GOAT
ghall2004
Post by ghall2004 »
Been down to see me old muckka RY220 last night
Kindly replace the track rod ends, needed some amount of heat to make the locking nut workable!
Due to my failure as a human being i forgot some nuts that i need to make some modification to the strut setup ( wont bore with details)
Have some issues to resolve
Need a new fuel tank! ( replacement from previous car now has a massive dent in it after the jack slipped last week and went into it!) and now wont read any lower thant 1/4 tank!
Radiator, water pump and a matrix to heater valve hose to replace this weekend
Front Strut re configuration
Exhaust re align and install poly hangers and pull tight with hose clips ( exhaust is fouling lca )
Car is defiantly getting there in terms of grip and handling through the corners. Corner entry speed, poise and overall feel and feedback greatly improved and i was seeing an improvement in speeds i was able to carry through the drive home from kelso to Edinburgh
Ryan was able to get from tow pretty much bang on "dead ahead" as suggested by ttrw2
camber isnt too bad out, as close as i could get it tbh and castor is again fairly close. after all i am a rookie *laughs*
Getting read to get a initial reading
Before just after track rod end change out
And how things stand at the moment
ghall2004
Post by ghall2004 »
Latest round of works completed
Roversport by cableguy radiator installation
Water pump replacement
Matrix to heater valve hose swap out
Didnt get many images this time, as it slows your down and no one really cares *laughs*
T series, water pump and rad replacement, so most of us should know the steps needed to get to where the pictures start.
This needed to be a full front end strip down, in my experience this is in the long run easiest and the most effective way of changing the rad and pump, especially when you end up encountering issues.
Everybody will have their own process this is mine, coupled with the fact the RS spec rad is DOUBLE the thickness of the oe fitment
The chaos begins
Rs Rad supported by "ram foam! :*laughs*: :*laughs*: Private joke peeps
Fan frame, bolts snapping left right and center from this ! *laughs* jesus
Existing rad frame to be reused/modded
Old rad, which actually was in pretty good nick, and didnt leak, so hopefully move this on to keep another t series on the road
And fast forward to now, where we start to see what will be needed to allow Rs rad to sit further forward, excuse the MS paint type skillz
Water pump now nice and accessible
Every bolt nice and easy, back top, negative , snapped instantly
Removed the cover to attempt to free the pump from the housing in the hope that there would be enough stud left to work with, just aswell i was changing this and my bodge days are over * ( claimed) check the nick of this bad boy!
Which left a fair bit of studd/bolt to work with heat and plusgas
Some time passed then boom! Great success
Socket cap stainless FTW, pump replaced
Then turned my attention to the RS radiator
The top brace that provides the secondary position for supporting the oe inter cooler and secures the rad into place needed to be modified slightly, i just rudely drilled a couple of holes, ghetto style yes, but worked fine, the same was needed on the lower fixing point of the rad frame too
Now fits
Rad then installed and time to check clearances and any other points that needed adjusting/trimming
Water pump to rad clearance, yes it is close but have verified against other RS installs, all A ok
General shots
fan Frame needed some attention, blue paint was an undercoat solution until i was able to get some better color match, see later images
And now not fouling
Thats better
Fans back in place , Pas cooler also back in as is bonnet catch assembly
Filled up with water for initial water test. all was ok, so proceeded to drain and filled with coolant.
Ran to temp and fans kicked in stage 1, heaters hot
Then just a case of re assemble
Some shamless plugs
Got some new RT stickers for the up coming summer event i have on the cards, thanks to Null_Byte for these as ever super fast dispatch
Front drivers side is a tad low, and lower than pass side. so need some further fine tuning, please excuse the open window fail and lack of tyre dressing
ghall2004
Post by ghall2004 »
Engine bay day
Samco sport facebook page
Chuffed with that
ghall2004
Post by ghall2004 »
ghall2004
Post by ghall2004 »
Only decent thing about rain
