R8 Cars with Infrared fobs - future support?
Use this board for any non-technical club car related topic including motorsport, trivia, insurance matters etc.
GTiJohn
Club Chairman
Re: R8 Cars with Infrared fobs - future support?
Post by GTiJohn »
rjessett wrote: Thu Jun 29, 2023 11:57 am The conversion kit is now in the RCOC club shop
There are two options, one is just the cable (if you already have the 5as and fobs you can use) the other is everything
https://store.rover-coupe.com/new-parts ... cable_only
200/400 members get £5 discount on the above - codes in the usual place, or pm me for it
This is an excellent kit - thank you for making it available :angel
I like Twin Cams, Single Cams, Turbos and 5-cam VVCs :cool
rjessett
Post by rjessett »
RoverRevival wrote: Fri Jun 30, 2023 8:22 am Thats a really good price considering NLA old kit was £150 on its own.
Thanks for your support. The pricing was the hardest part. its quite time consuming to hand make the cable, and the other parts are becomming less common than they once were. Hopefully we will be able to hold the price for as long as possible.
Main thing is to get a supported solution out there. We possible have the kit now to reprogramme infrareds (if I can get it to work). But, new fobs for that are nearly the price of this kit, and its no where near a good system. With this kit, you could get replacement fobs programmed by pretty much anyone with any of the popular key programming tools.
rjessett
Post by rjessett »
GTiJohn wrote: Fri Jun 30, 2023 9:27 am
And thank you for your efforts as well in supporting it John
rjessett
Post by rjessett »
Just a bump for anyone who has not seen this, and is struggling with a car with infrared remotes
The Rover Coupe Owners Club now has a replacement solution - and its in the club shop
https://store.rover-coupe.com/new-parts ... n-kit.html
GTiJohn
Club Chairman
Post by GTiJohn »
rjessett wrote: Sun Oct 08, 2023 7:35 pm Just a bump for anyone who has not seen this, and is struggling with a car with infrared remotes
I've had this kit fitted for several months now and don't give it a second thought, it's that good :cool
rjessett
Post by rjessett »
Just a bit of a bump for members who may not know we do these kits in the RCOC shop
https://store.rover-coupe.com/new-parts ... ssive_ring
5% off for 200/400 members
Dave T
Post by Dave T »
I would very much like to modify my 1994 214Sli Vin SAXXWYWHBBD056242 (21/07/1994) to the 5AS system.
Please update me on how to purchase the kit.
The work done in designing and creating this modification sounds truly amazing and invaluable!!!
Many many many thanks!!!
Dave T
rjessett
Post by rjessett »
Dave T wrote: Thu Feb 20, 2025 9:55 pm I would very much like to modify my 1994 214Sli Vin SAXXWYWHBBD056242 (21/07/1994) to the 5AS system.
Dave T
Thank you David for your comments. Are you sure your 1994 214 doesnt have a 5as already? Do you have any fobs at the moment? This kit is for the Infrared cars, which were typically earlier (infrared cars have a small dome on the interior light)
Please check what you already have before purchase.
For reference:-
You can purchase directly from the RCOC Shop - https://store.rover-coupe.com/new-parts ... ssive_ring
Dont forget the discount code! which is the same as used for the clock repairs (here:- https://rover200.org.uk/forums/topic/15346)
Mr Teddy Bear
Post by Mr Teddy Bear »
Is there a fitting option with this?
My 93 has been recommissioned and is in a shakedown process at the moment.
Everything works fine by using the key presently, are there potential problems just using the key?
Teddy Bear
216 Sli SRS Charcoal Met 1996
214Si Silver? Tempest Grey 1993
rjessett
Post by rjessett »
Mr Teddy Bear wrote: Sat Feb 22, 2025 1:43 pm Is there a fitting option with this?
For me to fit it for you? It could well be arranged. I've fitted a few for people who would rather I did it for them. That's not a option though the shop though, as Its only something I can do as and when, at home in Oxfordshire
Just using the key should be fine!
