Antifreeze
Antifreeze
Hi, Im going to flush the system next week - any suggestions on the best type of Antifreeze to use? Thanks
Re: Antifreeze
i always use the red stuff.
JS Performance group buy silicone breather pipes for T series turbo
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0997112995
- 220 GSi turbo
Re: Antifreeze
Me too. It should then be good for up to 4 years.Fatdave wrote:i always use the red stuff.
Re: Antifreeze
Red OAT is best
Re: Antifreeze
Depends on how often you'll be changing it.
There is no difference between the OAT and the standard blue stuff in terms of its anti-freeze properties. The only difference is in the corrosion inhibitors. The blue stuff lasts 2 years, the red / pink / orange stuff lasts 4 or 5 depending on the type. Personally I use the blue.
Re: Antifreeze
So blue is fine to use in the K serise ?
I was told to use the OAT red one as it can cause hgf.
ill use the blue then as its easyer to get my hands on.
if its NOT a rover forget it or regret it
1999 T Rover 416 Tourer Thitai Blue
1995 N Rover 220 Coupe Turbo Racing Green
1996 P Rover 216 Cabriolet Coupe SE Night Fire Red
Re: Antifreeze
I wondered about HGF using blue? I think a full flush then red is the way to go - many thanks for your help!
Sir Henry
Re: Antifreeze
As you don't try to mix the OAT, HOAT or conventional types you should be fine with any of them.
Vehicles currently owned (smallest first)
2002 Peugeot Vivacity 100cc scooter
1979/80 Suzuki 850 Trike Conversion
1995 Rover 216 twin cam (Honda lump) Cabrio
2004 Jag 2.5 X-type AWD Estate (manual)
1992 Dodge Ram 250 Day Van (3.9 V6, now on LPG)
Roxy Rover
Re: Antifreeze
I got red in mine to guys......
Re: Antifreeze
Doesn't matter what the colour is, it'll not make it any more/less prone to HGF.
Both are ethylene glycol, just the Red/Pink/Orange stuff has different additives to prevent corrosion.
I used blue in our old 1.4 for 60k miles without issue.
