geabox oil
geabox oil
my gearbox has a leak i think its a seal so ima change them all but my haynes manuall tells me to go to rover for oil anyone know what gearbox oil i need dont really want to be going spending out tons for rover certified
Re: geabox oil
Gearbox or engine giz us a clue?
Re: geabox oil
Giz us anuvver. Wot sort engine or gearbox?
If you think that doesn't matter, then the brand of oil wouldn't either!
Re: geabox oil
I think it's a 214. In which case - MTF94 ??
Re: geabox oil
Eh?
Well I wouldn't, the R65 with the 1.4 K Series takes 2 Litres of of Total BV that has been superseded by Total Transmission Gear 8 SAE 75/80 which is in mine now.
The Honda PG1 uses engine oil and should br drained every 24,000 miles
Re: geabox oil
I think its only the PG1 box that uses MTF94.
Has anyone got acess to a haynes manual? i think it lists what type of oil is used along with the capacity.
My Rovers to date:
1995 Rover 216 Coupe in Nightfire red
1994 Rover 220GSI in Tahiti blue
2002 MG ZR 105 in Solar red
1995 214i in Nightfire red
Re: geabox oil
Mt Teddy Bear is correct. Rover include an oil check sheet with the car manual.
Manual gearboxes - 1.4 is 75W/80W gear oil. Also, the PG1 box definitely uses 10W40 engine oil - but I knew this as I have a 1.6.
Re: geabox oil
sorry only just got on its a 1992 214 so 1.4 kseries single point injection dizzy cap type i believe its the original gearbox, if that helps and it gearbox oil needed. i do want to get another gearbox ( even better if i could find a 6speed that fits ;) ) but for now i need to keep this gearbox sweet
Re: geabox oil
oh and its manual gear box i know it matters the what engine/ gearbox i thought i put engine type and gearbox im unsure what 1 it is
Re: geabox oil
To match what's in it at the moment you need Total Transmission Gear 8 SAE 75/80.
I wouldn't put anything else in it. Remember it's fitted with plastic caged bearings!
so I would stick with what Rover recommended. You can find it on Ebay
