Honda Engine 216 Oil In Plug wells
Hello - My wife's 216 (15300 miles on the clock)! developed a misfire which turned out to be oil in the no 2 plug well which had pushed the plug lead out. The others had oil in as well but not so much. Surprised it ran with everything under oil. I've met this on my K series Rover 75 which has a special sealant spread over the camshaft carrier which leaked. I've searched this site but not found anything - maybe I'm not looking right. Looking in the manual there are o rings under the cam bearing / rocker assembly "posts" which seems to be straightforward to swop. Trouble is I'm not able to find any to buy. Could be I've not got the right name / description and I prefer them to hand before I start. Please can anyone put me in the right direction. Thanks
Colonel Mustard
Re: Honda Engine 216 Oil In Plug wells
Thank you Colonel - I didn't find when searched but I am 70 and grapple with computers!
That link takes you to another thread on our forum about a fix.
The simplified version of that thread is 'buy and fit these parts' - https://www.partsinmotion.co.uk/car-par ... 301-detail
Good luck
Good luck
No sealant on the honda engine. The gaskets are commonly available on eBay just make sure you get one with the four circle plug seals (not just the other gasket)
Hello. I've checked out the links but the engine top cover gasket sets appear to have the four seals that fit the top of the plug holes - ie underneath the cover. They do not seem to be "o" rings or have I got this wrong. I'm after the o rings that fit underneath the rocker shaft mounting posts or is it the same thing? Thanks.
redandwhitE
Am resurrecting this as I have same problem with my 416 honda D Series.
What was the outcome?
1995 416 SLi (Saloon & Tourer)
2003 45 Imp Diesel (plus spares car)
2004 45 imp Petrol
1993 416 GSi - spares
1972 Mercedes 350 SL
1998 Audi Cabriolet
2004 45 imp Petrol
1998 Audi Cabriolet
Remember the aftermarket for Rover is non-existent so look for same part but as a Honda
redandwhitE
Well the first part was a doddle. Just got to see about fitting them now. I'm happy doing the more mechanical stuff but engine work does put me off..... but we'll see.GTiJohn wrote: ↑Wed Jun 28, 2023 9:50 am The simplified version of that thread is 'buy and fit these parts' - https://www.partsinmotion.co.uk/car-par ... 301-detail![]()
Cheers info and guidance.
2004 45 imp Petrol
1998 Audi Cabriolet
2004 45 imp Petrol
1998 Audi Cabriolet
