Trailing arm differences - Drum vs Disc brakes
Plodder
Post by Plodder »
I have discs on the front and rear of my 91 416 .
Just wondering what the difference , if any, between the trailing arm for an R8 model with disc brakes and those with drum brakes?
Appreciate that the stub axle and fittings will be different but are all the necessary holes and brackets on a trailing arm for a disc brake if I brought one which was for or had a drum brake fitted .
James3990
Re: Trailing arm differences - Drum vs Disc brakes
Post by James3990 »
Yes trailing arms are identical.
I cover this in my project thread - https://rover200.org.uk/forums/topic?t=14243&start=120
Rover 220 Coupe Turbo
Rover 220 Coupe Turbo Racer
As James says they are the same just change the stub axle and handbrake cable :)
Plodder
Post by Plodder »
Thanks for the helpful information. At some point I’m thinking about rebuilding the trailing arm and hub and it would be nice to rebuild them off the car and just swap them out complete. Lots of other jobs in front , but the trailing arm bushes are 16 years old so probably due to be renewed soon.
Plodder wrote: ↑Sat Mar 07, 2026 10:39 pm Thanks for the helpful information. At some point I’m thinking about rebuilding the trailing arm and hub and it would be nice to rebuild them off the car and just swap them out complete. Lots of other jobs in front , but the trailing arm bushes are 16 years old so probably due to be renewed soon.
I have powder coated ones with bushes in and stub axles both types the biggest issue is the back plates NLA and usually turning to dust , so when looking for secondhand ones to rebuild the back plates are more important in my opinion .
Plodder
Post by Plodder »
961tat wrote: ↑Sun Mar 08, 2026 7:25 am I have powered ones with bushes in and stub axles both types the biggest issue is the back plates NLA and usually turning to dust , so when looking for secondhand ones to rebuild the back plates are more important in my opinion .
Do you rebush them with standard rubber bushes or with poly bushes?
Plodder wrote: ↑Sun Mar 08, 2026 2:37 pm
Woops that should have said powder coated doh :slapme
Standard rubber for the road, rubber absorbs shock and vibration , on uk road needed poly good for track cars and getting rid of tooth filling on the road gumpy old get i am :tt2
Plodder
Post by Plodder »
I’m with you on a softer ride but that’ll start a good discussion :laughing2
