There are many things that will remove our cars from the road - some of which we cannot do much about (the juggernaut pushing you into the Armco), some of which already have technical solutions (HGF) and are so only a matter of financial viability and some of which the solution isn't known widely, or not at all.
We discussed this topic at the AGM as we want to understand if there are things we can invest some of the club's funds to find solutions to ensure we keep as many of our cars on the road as possible.
We can use this thread to identify the common faults and where we have fixes/ workarounds etc and where we don't. If we don't have them, we can then investigate if solutions can be found and made available.
So for starters:-
1) Rusty sills - generally patched but where can you get sill repair panels from? Info and links for each bodystyle needed. For example - http://www.carbodypanels4u.co.uk/rover/ ... sill-skin/ for 5doors
2) Honda 1.6 fuel relay causing engine stalls. Normal solution is just to replace the relay with another one an hope! Alternative relays have been suggested but where is that info? Link?
In the medium-term, we can include this info on our club website
Now it's your turn
