Recently treated myself to a Rover 416 Tourer to go alongside the 216 Vitesse. We've recently just had our first child and unfortunately the Vitesse doesn't have seat belts in the back to fit the car seat as it just missed the cut off date in 1986 (although could go in front as no airbags but prefer the back). I'm really happy with it and been using it pretty much as a daily driver recently. Lots of room and the boot space is really handy for all the baby stuff and also the family dogs.
Engine runs really nice and the previous owner said he'd replaced the original plastic throttle body with a better aluminium one off a different model. I think I've read something about this being a good mod to do but need to look into it a bit more. It does receive just over 50MPG on a run which is great and pulls nicely. The only real problem with the engine is that it seems loose a little coolant. The previous owner thought it was the heater matrix weeping although I'm fairly convinced now after using it for a few weeks that it may actually be the head gasket. I seem to get a little coolant on the lip of the block where the head doesn't cover on the timing belt side - if that makes sense? It certainly isn't mixing with the oil as it's still really clean and the exhaust runs clear so perhaps just leaking out rather than going into somewhere it shouldn't be..
Bodywork it acceptable all around except from the roof which has some bad lacquer peel. I've never seen car with it so bad. It's also purely on the roof and not the bonnet as well like you would expect so wondering if someone has maybe had a car cover on that has been damp and rubbing. If I'm passing a bodyshop at some point I might see about getting repaired.
The radio/cassette is a Rover R760 and unfortunately the previous owner was a little hopeless and hasn't sent me up the history for it which is annoying. Does anyone know if this radio has a keycode or not? I'll need to disconnect the battery at point and don't want to be left without it. Looking on ebay some seem to have codes and others not.
Hopefully I've attached some pictures for you...
Tom.
