Cabby boot lid wiring
Rovernut
Post by Rovernut »
Hi
Has anyone else had snapped/trapped wires in the rubber trunking from boot to boot lid? Mine have trapped and eventually cut through to cause loss of number plate lights.
Any solutions? Will they solder back together or is it a new part loom?
Chris
mach1rob
Post by mach1rob »
Common on all models unfortunately.
Yes you can rejoin rather than replace, only awkward bit is if there isn't enough slack on wires.
matthewsemple
Post by matthewsemple »
On our Coupe they were soldered back together to get it through the MOT. The Cabriolet has the same bootlid so I am sure it is the same problem.
